How do you change the T-map on a model in DS4.6?
Turk_WLFTurk_WLF Posts: 177
I have an airplane model that was made for Poser but since my version of Poser (7) is so old, it doesn’t work as it should however I can use the Model in Daz Studio 4.6 Pro just fine. I have made a new Texture Map but I can’t figure out where or how to change the Texture Map in Daz Studio 4.6 Pro.
Thanks,
  • srieschsriesch Posts: 4,243
    Select the Surface selection tool in the toolbar, click on the surface, then In the "Surfaces (color)" pane. Click on the dropdown arrow or icon in front of whichever parameter(s) you want to change (if you don't know what you want, you probably want the Diffuse parameter.) You can then browse to your new texture map (or select a different one already used in the scene, or set it to none.)
    Your view may look different depending on how you have DS set up, but I've attached a screenshot to show what I'm seeing when I do this.
    1595 x 848 - 304K
