V4 Powerloader from the Daz lib versus Runtime
I can load V4 from the Poser Runtime directory in DS, and it runs this DSB I guess, which starts the Powerloader...which is a nice (what morphs to include) menu.
...but I am moving almost 100% away from using the Poser Content lib, but I still want to run that PowerLoader to load V4, if possible?  Is it possible to run a Powerloader from the Daz format library?  I tried moving the CR2, DSB and other stuff in there, but it does not run.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    You could try loading a V4, saving a scene, and then right-clicking on the loaded figure - that used to give an option, as i recall, that let you change the morphs via Power Loader but I haven't tried it for a while.
  • SixDsSixDs Posts: 2,384
    Right-clicking on the figure in the viewport will open a dialogue box that has the powerloader at the bottom, which will open it, allowing you to choose which morph packages you wish to load, as you said, Richard.
    OK, I'll give that a try, thanks!
