Studio Program Showing Too Small to Read in HD Laptop
Hi, was unable to find anything on this so hope it has not been covered elseware...  I own a new HP spectre 15" 360 Laptop running Windows 10 Pro 64 running at its normal resolution of 3840 x 2160 and when running DAZ Studio it is impossible to see anything as everything is so small.  Without fully changing my screens resolution or setting that will effect all my other running programs,- which are well seen using this native resolution - is there any way to increase the veiwing size of Studio so I can see everything clearly?  If not will Windows 10 Pro allow me to change screen resolution for specific programs such as Studio without affecting my other programs or are there any apps you know of that will do this?
As always many thanks to my fellow Forum Members who have assisted me in the past.
Wade
  • borgtrekkerborgtrekker Posts: 112
    Since there have been no responses to this inquiry I have submitted it to the DAZ Tech Support Team.
  • Richard HaseltineRichard Haseltine Posts: 111,294
    Sorry, I thought I had replied - probably another thread on the topic. DS will respect the Windows (if that's what you are running) display scaling but it doesn't currently have a separately scalable interface of its own. we know this is being worked on, but it is not a quick task as it requires removing all use of the Qt 3 application framework (as a prerequisite, a necessary bit not necessarily a sufficient step).
    Have you considered using Windows 10 built in Magnifier? It is far from perfect, and slows you down, but I often need it, set to add 50% (which gives a magnification of 150%), what with my poor eyesight.
