surfaces tab
My surfaces tab has stopped allowing me the ability to copy and paste texture maps from one item to another. Here is what I try to do...
1. Click on first item
2. Select surfaces tab
3. Right click
4. Select "Copy select surfaces"
5. Click on new item
6. Select "Paste to select surfaces"
In the past, the texture map would then paste to the 2nd item. As of yesterday, it stopped doing that for no apparent reason.
  • fixmypcmikefixmypcmike Posts: 19,730
    Did you select surfaces?
  • Richard HaseltineRichard Haseltine Posts: 111,700
    Where are you clicking, on the model with the Surface Selection tool? One potential issue is that copy and paste copies parameter settings, but the shader in use, so if the surface you are copying from has a shader with unique property names paste won't have any effect on a standard shader.
