Daz will not work!
wolfcub9393wolfcub9393 Posts: 0
Hello, I'm new to here and to 3d modelling. I thought DAZ would be a good way to start.
Immediately after installation I run into a problem ’ The procedure entry point ?put-LastRecID@QUeryResult@vsql@fbl@@QEAAI@Z could not be located in the dynamic link library VShared_x64.dll.’
I'm running a high end i7 dual core Intel computer, win7 64 bit Pro, 4 gig ddr3 - win7 is fully updated.
Uninstalled everything concerned with DAZ including CMS, turned off antivirus - reinstalled and same problem!
Any help would be appreciated thank you, I really would like to have a go at this.
  • SzarkSzark Posts: 10,634
    Unless some of the serious Geeks among us can help this might one for a support ticket via the Help link and the top of the forums and direct it to the tech department.
    Also Daz Studio is no for modelling but for rendering.
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Did you install to a drive other than C:? Reportedly people have had this issue if they do that, and fixed it by installing the application to C: (that doesn't oblige you to place your content there). If that is your issue, please make or add a note to an existing bug report - bugs.daz3d.com, requires a separate account to the store and forum.
  • wolfcub9393wolfcub9393 Posts: 0
    The install was to C: but not quite as per default - I chose to create a folder called Daz and instructed it to install to that location.
    Does it work if you install with the default locations?
