Lainey Hair
tophandtophand Posts: 139
I have used (and loved) Lainey hair without problem. Windows glitched and I had to reset it and re-downloaded all my material. Now when I use Lainey Hair, the "cap" (or scalp?) under the hair shows.  I am not sure if this problem is related to redownloading everything or something else I have managed to screw up.  Am I missing a step or file?
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Iray or 3Delight, or Poser? Or are you just looking at the preview?
  • tophandtophand Posts: 139
    I found it works in 3dl  but not in Iray. Attached are (very) quick renders
    604 x 636 - 109K
    566 x 673 - 126K
    It does have materials for both Iray and 3Delight - are you sure you are using the Iray materials for Iray?
  • agent unawaresagent unawares Posts: 3,513
    Did you apply the apply first preset?
    I used the apply 1st. I am using the MDL material
    AHA!!!!    It works if I don't have Gen 8 preselected, add the hair, then use apply 1st and then fit to
  • nannerfkmnannerfkm Posts: 74
    Ah...it's always the simple things. An extra step that I have forgotten to do. Thanks for the reminder!
