how to export/import rigidity map preset? like importing uvs?
MistaraMistara Posts: 38,675
I see how to import alternate uvs,
but how do you import/export rigidity maps as a character preset?
focusing on toe nails and hair barettes.
DS 4.9 pr 4.10
Thanks! smiley
  • Richard HaseltineRichard Haseltine Posts: 112,067
    A Character Preset used to load a new character will bring in geometry and rigging changes, as will a Scene or Scene Subset - as will a Wearables preset, which might be relevant for you.
    yes,
     cool
    stuck on :
    how to make the preset call only the #geometry and not the rigid groups?
    for example, a shirt for g2f has rigid buttons.
    the buttons are dodgy
    trying to make a load preset that will load the geometry but not the rigid lines
    I'm not sure what you mean - are you wanting to completely remove the rigidity Groups? I don't think you can do that, though you should be able to replace the existing group with one that has only a single polygon (on the back of the button, perhaps).
    edited March 2018
    could try the 1 poly method.smiley
    been trial and erroring to come up with a url to point to an alternate #rigid,
    so far is only error  sigh
    is all under #geometry, how to parse it?
    load the geometry to an array first?  can a daz script do that?
    curly braces >.<  c++ makes me seasick.
    Post edited by Mistara on
    edited March 2018
    Yes, it's DSON (JSON derivative) and Daz Script can turn that into a data structure. This is my code from the fix Duplicate IDs script:
    function prepFile( name ) {	// Open the file, read it into a string	// and convert to a JSON object, which 	// is to be returned		// open file	var file = new DzFile( name );	if ( file.open( DzFile.ReadOnly ) ) {		var ourObject = JSON.parse( file.read() );		file.close();		return ourObject;	}	return undefined;}
    which is given the fiel name, opens it as read-only, and reads the whole thing in and converts it into an object (that needs more error trapping than it has).
