Toon render option?
darkguyver1994_a1285f4265
When I first started using DAZ Studio there was a toon render option. I'm not seeing it anymore. So what do I use to make my DAZ renders cartoonish?
If you enable Show Hidden Properties in the Render Settings pane option menu (the lined button in the top corner or right-click the tab) you will see the Render Style button at the bottom of the list when the engine is set to 3Delight. Remember, however, that this is just a switch telling DS to use a different version of the Default Daz Shader - materials using different shaders will not be changed in any way, so it may have limited use on more recent products.
What would be the best toon shader product to use?
Iray? Probably this : https://www.daz3d.com/oso-toon-shader-for-iray
And there are several for 3Delight in this store. I have https://www.daz3d.com/visual-style-shaders and find it good, though I have not done many toon renders to know which is best.
I like a combination of pwToon and the material shaders made by user name 'Neo Genesis' on shareCG.com's addons for the pwToon shaders. pwToon is a 3DL set of shading that you must manually apply to each of an model's Surfaces zones in the DAZ Studio Surfaces tab.
https://www.daz3d.com/pwtoon
http://www.sharecg.com/v/69733/gallery/21/DAZ-Studio/Crescents-pwToon-Cel-Shaders
You need both products. The 2nd is free.
The OSO product realy didn't deliver what I was looking for. I'll check out the visual style shaders.
