Iray viewing issue
Hello,
I noticed some Iray textures do not appear correctly in the viewer screen. When I render the model, the texture comes out nice, but it would be helpful if I could see the texture on the model correctly before rendering, especially if I'm playing around with makeup for characters. I noticed that I don't have this problem if I choose 3Delight textures. Is there some kind of setting that I need to correctly set so that I can see Iray textures correctly, or at least as close as possible to the actual texture?
Thank you for your help.
  • Richard HaseltineRichard Haseltine Posts: 111,291
    Are you using the nVidia Iray preview mode or Texture Shaded (which is the default)? If the former, you may need to adjust things in the Draw Settings pane, if the latter see if you can use the former on your system.
