Yvette Hair Morphs Don't Work
FauvistFauvist Posts: 2,291
edited March 2018 in The Commons
https://www.daz3d.com/yvette-hair-for-genesis-3-8-female-s
I'm using it on Genesis 2 Female.  It fits fine.  But some of the morphs don't work.  Some do work - like the size of the crown, and the height above the ears.  But madeningly the morph that removes the scarf doesn't work.  And I can't find any opacity setting in the surfaces tab.  Any ideas what's causing this?  Or how to fix it?
Thanks!
1042 x 1067 - 2M
Post edited by Fauvist on
    I'm using it on Genesis 2 Female.  It fits fine.  But some of the morphs don't work.  Some do work - like the size of the crown, and the height above the ears.  But maddingly the morph that removes the scarf doesn't work.  And I can't find any opacity setting in the surfaces tab.  Any ideas what's causing this?  Or how to fix it?
    Thanks!
    If you auto-fit a hair to a character it's not meant for, you lose the bones for the morphs. Instead parent it to the head after manually placing it correctly on the character.
  • DeathKnightDeathKnight Posts: 98
    edited March 2018
    Change the Scene Identification for the hair. Load it into the scene with no items selected. Select the hair and right click on the Scene tab, go to Edit then Scene Identification. Change both the Compatibility Base and Preferred Base to Genesis 2 Female. Now fit the hair to G2F. All the morphs should work.
    This can also help with all kinds of items when crossing figure generations. It doesn't work 100% of the time but it's a pretty good workaround.
    Post edited by DeathKnight on
  • freni-kynfreni-kyn Posts: 394
    Great info.  Thanks!
  • FauvistFauvist Posts: 2,291
    Thank you for the information.  I'll try it.
