Should Expressive for Genesis provide morph parameter dials?
I've installed Expressive for Genesis. I see the expression 'poses', for fixed/complete application, but cannot find associated morph parameter dials for variable/partial application. Should they exist?
As you can see in the attached image, I'm using a new Genesis figure and selecting its Head. I've reinstalled Daz Studio and Expressive a few times each. I've deleted and recreated my content management database (which fixed a problem with the poses not showing up in the Smart Content panel, but did not add parameter dials).
If Expressive does have morph dials, any suggestions, or is there a way to manually inject these morphs into an existing scene object?
If Expressive does not have morph dials, is there a way to generate them from the poses?
They don't have dials, but you can make your own if you want to invest some time in it. The process is explained in this thread : http://www.daz3d.com/forums/discussion/6484/
I do this for most of the expressions that don't have dials, makes it so much easier to mix and match bits of different expressions (plus they'll also get recognized by the Genesis Expression Randomizer if they have a slider).
Awesome! I was getting a little frustrated :). You are wonderful.
