Cinema camera for pre-vis
I am directing a movie in the next few months and I wanted to use Daz3d for my previs. The biggest trouble I have is that the camera in Daz doesnt really behave like a real camera on set. I want to set proper lenses (like 18, 35, 50 for example) and want to simulate actual dolly moves. On a real camera, you can pan and tilt, but the way Daz's camera works its more of an "orbit". That's fine for 3D but it doesnt translate to an actual movie set.
Does anyone know how to do this? Even better, it would be amazing if there were actual cameras, dollies and cranes that I could import into Daz so that I am making a true pre-vis with a virtual camera. Then I could show diagrames to my crew on set, about where to set up the dolly and such.
Let me know if you had any experience with this and have any solutions.
Thanks in advance.
  • HavosHavos Posts: 5,703
    Look at the parameter tab with the camera selected. Under camera you can change the focal length to 18, 35 etc, and there you can use the x, y, x translation and rotation to move the camera around
  • j cadej cade Posts: 2,310
    As havos mentioned setting up focal lengths is pretty simple. For cranes/rigs if you're comfortable translating information there are some good blender tutorials about setting up rigs to have cameras move more realistically (basically use primitives and parent them to each other + parent the camera to them) the only *real* major limitation of the DS cameras is that you cannot set a focus object.
    Specifically... I think I used this tutorial?
    You can do everything except the focus in DS. Also if you lock the parts of an element that you don't want to move (ie lock the translation of the boom arm) it becomes very easy to pull around with the manipulators in the view
