Trouble Installing DAZ Content(More information inside)
RenatoDiasRenatoDias Posts: 34
Hello, everyone.
I've tried to install Aiko 4(V4.2 needed), and I have Victoria 5. Even with V5, Aiko 4 won't install, saying it couldn't detect the required files. Now I would like to know: Why have such a restriction? I thought I could install Aiko 4 with V5, but Aiko 4 installation aborts with "Dependency Error: Required Files not found". Am I doing something wrong?
What are those dependencies needed?
Thanks. I really want the models to work.
  • Richard HaseltineRichard Haseltine Posts: 111,701
    You need Victoria 4 - it isn't the same as Victoria 5, or 3. Generally speaking a different number means a different base figure.
  • RenatoDiasRenatoDias Posts: 34
    I've installed both V4 and V5, all of their base files and materials. I have both V4 and V5 installed
  • SzarkSzark Posts: 10,634
    But are you installing Aiko 4 in the same location as V4 as that is what the error seems to be.
    Yup, same location. MyLibrary.
    Humm I am not sure what the problem is then..have you tried downloading again just incase of a corupted DL, rare but it does happen and trying to install. Is there a Zip file for Aiko 4 in your Product Libaray as that might be a way around the issue.
    By any chance have you run the DzCreateExPFiles-V4.bat file lately for V4. Might be worth trying to see if that fixes the issue. the bat file should be in My Library/Runtime\libraries\!DAZ
  • fixmypcmikefixmypcmike Posts: 19,730
    You need to install A4 to the same content folder as V4 -- specifically, the file ":Runtime:Libraries:!DAZ:DzCreateExPFiles-V4.bat" is the dependency - A4 won't work without it.
    The actual Victoria 4 figure, not the Victoria 4 shape for Genesis? If so then you need to install Aiko 4 to the same location as the V4 base.
