Headshop Not Showing in Edit Menu
Purchased headshop - thought installed correctly - will not show in Edit Menu?   Anyone able to explain how come? I lead it to the right install path on my computer.....thanks for any help.
  • Richard HaseltineRichard Haseltine Posts: 111,790
    Does it require its serial number entered in Help>About Installed plug-ins, and then DS restarted? The serial number should be available via right-click on the product in DIM (if it's connected, I think) or from the serial numbers page of your account.
  • having similar problem... DAZ studio 4.15 and HeadShop 14 ; does not show up in edit menu... also not in the about plugin list
  • Installation issues usually caused by attempting to install with either DIM or DAZ Central. Remedy: please read!!!!!! the README that has detailed installation guide.
    HeadShop comes with its own installer, there are also videos of how to install: https://youtu.be/5N-8KE4BCbo  and also https://youtu.be/QACNeyStmT0
    If still no luck, email tech support at [email protected]
