closest daz3d render results in Cinema 4d?
If I want to get to closest render results in Cinema 4d from daz3d with using https://www.daz3d.com/skin-shading-bundle, what are some thoughts about how to achieve this?
  • wolf359wolf359 Posts: 3,951
    edited March 2018
    Hi First consider what render engine you are using in C4D
    There are several third party in addition to the Maxon C4D native
     engines. (Redshift ,prorender, cycles4D,Vray etc)
     NONE of which will  directly translate the settings of this Daz Iray product
    Of course you may be able to import any image based skin maps from Daz studio as a start
    However once you leave Daz studio, you will have  learn to create skin shaders using the native Shader systems of the C4D render engine.
    Post edited by wolf359 on
  • wolf359 is correct; even if using Iray in both, unless you use an MDL skin shader, you won't get exactly comparable results.
