Genesis 2 V6 geo ask
JogitechJogitech Posts: 11
Hello
my ask the geographtet genital of V5 must upgrade for v6 or came a new?
  • Richard HaseltineRichard Haseltine Posts: 110,839
    There is a new genital add-on in the Victoria 6 pro bundle, but I believe [people have been able to convert the V5 version (as a conformer, at least - given that the mesh has changed it probably won't Geo Graft without further work).
  • sfaa69sfaa69 Posts: 353
    Richard, I see no mention of genitals in the list of what's included in the pro bundle. Am I missing something, or did you leave out the word "not"?
  • drakkendarkdrakkendark Posts: 57
    sfaa69,
    Usually when they release these things the genitalia is in black because they have not released it yet. If you buy the Pro Bundle, the genitalia should be downloadable when it is released, or at least that is the way that it has been so far.
    Hope that this helps...
    -DrDrk
    Greetings,
    It's in the Pro pack, and is downloaded as part of it, it's just not listed on the product page.
    -- Morgan
  • ZenrelZenrel Posts: 245
    The pro bundle does indeed have it.
  • cwichuracwichura Posts: 1,042
    However, it's the same as the nerfed version of the Genesis Female Genitals, so don't worry about buying the Pro bundle to get it. Calling that bump 'female genitals' borders on fraud. You can't even get a proper cameltoe effect out of it (I rarely render full frontals, but I have used the original (pre-nerf) Genesis Female Genitals as a way to get a better looking cameltoe effect than you get with the various genital crease morphs that have been released for Genesis).
  • wyzarddocwyzarddoc Posts: 3
    Tried the genitals but can't seem to get the texture to work. Any suggestions?
    thanks
    click on the genitals then click on the skin texture that is the same with the body.
  • robert_poirotrobert_poirot Posts: 34
    In render the genital skin gives a triangle that in shade differs from the rest of the body. But that is not new in a lot of Daz3d sold characters that is a problem. (most extreme example is the dark skin of Tyrese for M5.
    For female Genesis 1, i mostly use "Body Morph Resource Kit 1" that will ad some "Female Genital Shaping Morphs" to genesis, even without the genital prop. This works for nudist and camel-toe a lot better than the genital prop.
    But for Genesis 2 there is also no resource kit..............................................It will probably take until the release of Genesis 3 to get Genesis 2 complete :-).
    That shouldn't happen if you apply the materials for the figure to the genitals as well.
