missing file
missing file help pless
data/auto_adapted/evd1_sdisplay_1044/geometry_68ff0fa2_8c43_f771_a95d_0183c14e8c78/evd1_sdisplay.dsf
data/auto_adapted/evd1_sdisplaydoor_360/geometry_b95c8297_09be_04ab_ebdb_c940b9bb86f3/evd1_sdisplaydoor.dsf
959 x 714 - 65K
  • Richard HaseltineRichard Haseltine Posts: 112,099
    Is that from an old saved scene of your own or from a product? Those are files which DS geenrated for imported content that hadn't been explicitly saved as assets - it's been a while since that has been done, now assets are embedded in the scene file if they are not yet assets - so if it's your own file you need to work out what it was that was imported and saved, then reimport it in place of the missing item. If it's from a product or freebie then the creator needs to fix it, assuming it was installed correctly (check to see if those files are in the zip).
