Iray Enviroment Dome
Hello, I am unable to see the applied hdri image on the iray dome. The lighting part works, but the image part is white. Tried changing the settings, changing the images, even back to stock image, no matter what I choose it remains white. This in the iray viewport, I have not tried rendering an image. Is there a setting I am missing?
  • Richard HaseltineRichard Haseltine Posts: 111,311
    Try rendering, to make sure it is working, and then you would need to look in Draw Settings to see why the HDR did not preview if it did render.
  • Ok, did a render and all was well. Switched back into studio, and the image is seen correctly in viewport now. Must of been something wonky that corrected itself, thanks for the help!
