Black 9or blanked) eyes
this is an old M4 character from a three character set all M4 based this is the only one with these black eyes and nothing I try will get rid of them. All have been IRay "baptized".
I seem to remmber this problem from an while ago but don't remember the solution.
535 x 653 - 568K
  • nemesis10nemesis10 Posts: 4,009
    Look at the cutoff opacity for cornia and eye moisture/tear
  • cclesuecclesue Posts: 420
    Done all of that stuff. Didn't work
    In the Daz Default shaders, there is one for thin wall glass or use the one for water.  There is clearly something black and opque covering the eyes.  It may have too much refraction possibly.
    Since I wrote the last comment I tried different characters and thet worked just fine. In fact the ones from JM Ovidious look even better than the original.
  • 3Diva3Diva Posts: 12,058
    I had a similar issue (I'm not sure if it's the same issue as you're having): https://www.daz3d.com/forums/discussion/86216/help-please-eyes-rendering-black-or-pixilated
    The "fix" for the issue I was having was given to me by @Thor - they said:
    Quick fix: Go to Surfaces > 5_Sclera
    ... and set "Refraction" to Off.
    That fixed it for me. Maybe it will help you? (I hope so!)
