Ignore this science fiction lab scene freebie.
StratDragonStratDragon Posts: 3,290
edited June 2013 in Freebies
[edit] I made a feebie, it didn't work when I tried it at home, I took the link down, I changed the tile of this thread to "ignore this" which got more responses then I did when it said "freebie", anyway I fixed it the file, I put the updated one back up on share CG.
http://www.sharecg.com/v/69900/browse/21/DAZ-Studio/Gorilla-Lab-2000
Post edited by StratDragon on
  • robkelkrobkelk Posts: 3,259
    Grabbed the zip for the OBJ files - thanks!
    And the other download you were thinking of is here: http://poserdirect.com/free_thebigone.html
  • SimonJMSimonJM Posts: 6,102
    * camps out and sets flag in the abandoned thread * :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,655
    uhm will this be moved to the commons as this is a removal, not an offer of a freebie?
  • KeryaKerya Posts: 10,943
    edited June 2013
    It is a free free freebie thread!
    It offers a free ignore ...
    Post edited by Kerya on
    Hmmmmmmm!
    500 x 349 - 39K
  • Richard HaseltineRichard Haseltine Posts: 111,701
    I couldn't have put it better. Or at least, I'm not going to exert myself to try.
  • KickAir 8PKickAir 8P Posts: 1,865
    Gotta admit, that one's impressive. :D
  • StratDragonStratDragon Posts: 3,290
    edited June 2013
    Link restored in first post.
    edited June 2013
    Moved to the Freepository as it is a restored, not ignored, freebie.
    Post edited by Chohole on
  • Scott LivingstonScott Livingston Posts: 4,352
    I predict that "Ignore this freebie" will generate even more response than just "Freebie" or "Ignore This" alone. Thank you for sharing this!
  • WilmapWilmap Posts: 2,917
    Now shall I ignore or shall I download the freebie?
    edited June 2013
    I think the studio files will work with 4.5, not just 4.6.
    What can be Ignored is the missing texture message btw its from the glass surface shaders for DS that have an unrestricted use clause so if you have them you wont get the message, if you don't you probably don't need them..
    The obj files will work with everything else prior to 2.5/2.6 but you may need to turn smoothing off on some of surfaces because the angle cuts worked for some props not for others.
  • fixmypcmikefixmypcmike Posts: 19,730
    Download it, but look the other way.
    Then add it to a scene, but set it to invisible...
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,310
    Thanks!
