Accessing bump maps, specular maps, etc
Hello,
I'm making an export plugin and I want to access the various textures (bump, specular, etc), as I understand it I need to use DzDefaultMaterial::getBumpMap and such.
In pseudo code (with error checking removed for brievity) I have something like this:
int numNodes = dzScene->getNumSelectedNodes();for( int i = 0 ; i < numNodes ; ++i ){ DzVertexMesh* pVtxMesh = dzScene->getNode( i )->getObject()->getCachedGeom(); //using getCachedGeom here because I'm making an alembic-like exporter, I need transformed vertices, not T-pose DzFacetMesh* pMesh = qobject_cast<DzFacetMesh*>(pVtxMesh); ExportMesh( pMesh ); DzShape* pShape = dzScene->getNode( i )->getObject()->getShape( 0 ); int numMaterials = pShape->getNumMaterials(); for( int j = 0 ; j < numMaterials ; ++j ) { DzMaterial* pMtl = pShape->getMaterial( j ); DzTexture* pAlbedoMap = pMtl->getColorMap(); //This one works fine ! if( pAlbedoMap ) //Do stuff with albedo map DzDefaultMaterial* pDfltMtl = qobject_cast<DzDefaultMaterial*>(pMtl); //Always return NULL :( if( !pDfltMtl ) continue; DzTexture* pBumpMap = pDfltMtl->getBumpMap(); if( pBumpMap ) //Do stuff with bump map }}Either I can't get a (non-null) DzDefaultMaterial, either I get one (by accessing sub-materials through DzMaterial::getMaterial(0) for exemple) but then DzDefaultMaterial::getBump return NULL.
Note: for my tests, I'm using vanilla "genesis8 basic female", which DOES use bump maps.
I'm new to Daz SDK, but quite frankly, I find it quite confusing (for example why is there a hierarchy of materials accessible with DzMaterial::getMaterial(int which) ? ) and very much lacking in term of documentation.
Can you please point me in the right direction ?!
Cheers
I would assume your cast to DzDefaultMaterial returns null because the material simply isn't one. I believe that DzDefaultMaterial is really only included as a reference implementation of DzMaterial, and in most cases actual materials don't inherit from it.
You can enumerate the properties of the base DzMaterial with the pseudo-code below -- among these properties I'm sure you'll find what you're looking for. Many classes in the SDK extend DzElement, which provides among other things the ability to assign a set of DzProperty objects
for (int i = 0; i < mat->getNumProperties(); i++) { DzProperty* prop = mat->getProperty(i); qDebug() << "prop " << i << " " << prop->getName(); // Cast prop to DzFloatProperty, DzImageProperty, etc }
