How can I match resolution in daz3d with an imported image photoshop?
Hi,
Im trying to add a picture(like a wall poster,edited in photoshop)in to a render in daz3d but cant get it to be the same resolution. I guess I need the same resolution set in both daz3d and adobe but I cant find where in daz3d I can see the resolution or am I thinking wrong here?
Best Regards/
Mipe
  • Richard HaseltineRichard Haseltine Posts: 111,382
    The image size iss et in Render Settings, in the General group (note that only the pixel dimensions matter, PPI is not relevant).
  • mipe212mipe212 Posts: 7
    Hi Richard
    Thanks for the quick reply. I tryed to set the size and I got it to look okay in photoshop now. However when I add it as diffuse map in daz3d it scale totaly wrong. See attached pictures, might explain better than I can :)
    397 x 301 - 288K
    339 x 74 - 25K
    The images are very unclear, but I suspect you are applying the image to a plane that is meant to be visible through the window in the first scree shot? If so you need to adjust the plane's proportions to match the image proportions - set the x-scale of the plane to image width / image height * 100.
