Attention Petipet Ensk Station Does Now Work
RbugRbug Posts: 166
edited March 2018 in Daz Studio Discussion
Ok well hopefully this gets your attention. If you were involved in the repair of the Ensk Station, for some reason the second file loads nothing but those frustrating grey boxes. it referes to a location that does not exist at all anywhere in the known universe. I even tried to trick it into loading something by transfering all the files into a new folder called Ensk Outpost, well that did not work either. I put in a Help Center Ticket on, March 06 2018, and today March 15 2018 i was told it was fixed. No it wasn't. This has become a source of total frustration. Can you Petipet help?
Well Seems someone was correct in assuming that there was a third part to this item........Thanks for all the help i did get
Post edited by Rbug on
  • RbugRbug Posts: 166
    seems I have a small problem with it's content. When I try to load the second file (Ensk ! PRE EnSt2 IR) it gives me the infamouse missing file popup (see images) and all i get when I click on OK is those nasty grey boxes.  I have checked to see if when manualy installing it i missed a data file or two but it seems that I have not. Can someone help me untangle this. Oh and also the parts I am missing show up on the product page (PopUp 8 see image) Thank you in advance.
    1000 x 769 - 178K
    1155 x 856 - 169K
    1080 x 608 - 119K
    edited March 2018
    Threads merged
    Did you uninstall the first version?  then download and reistall the new fixed version?
    Post edited by Chohole on
    yes i did... when it was delayed in getting it fixed i removed it completely.....
    So are you using DIM, Connect or a manual install?
    manual install, as i was told this should not make a difference. I also tried the dim, and the connect nothing
    And you have all the files in the right location?
    Ensk Station DS
    • You can find new icons for loading this product in the following DAZ Studio Folders:
      • “Props:Petipet:Ensk station:Cameras preset”
      • “Props:Petipet:Ensk station:Materials:3Delight”
      • “Props:Petipet:Ensk station:Materials:Iray”
      • “Props:Petipet:Ensk station:Scenes”
      • “Props:Petipet:Ensk station:Scenes:3Delight”
      • “Props:Petipet:Ensk station:Scenes:Iray”
    • You can find new icons for this product in the following DAZ Studio Categories:
      • “Cameras”
      • “Materials:Architecture”
      • “Materials:Iray:Architecture”
      • “Props:Architecture”
    as per the files list from the readme   http://docs.daz3d.com/doku.php/public/read_me/index/49633/start
    ok well here is a copy from the missing files warning, this is where it goes awry:
    data/petipet/ensk outpost/block1/block1.dsf
    data/petipet/ensk outpost/block2/block2.dsf
    data/petipet/ensk outpost/block2a/block2a.dsf
    data/petipet/ensk outpost/corridor/corridor.dsf
    data/petipet/ensk outpost/generator/generator.dsf
    data/petipet/ensk outpost/platform/stand.dsf
    runtime/textures/petipet/ensk outpost/pteno_corridor.jpg
    runtime/textures/petipet/ensk outpost/pteno_corridor_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_corridor_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_corridor_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_corridor_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_door.jpg
    runtime/textures/petipet/ensk outpost/pteno_door_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_door_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_door_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_door_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_glass.jpg
    runtime/textures/petipet/ensk outpost/pteno_glass_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_glass_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_glass_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull10.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull10_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull10_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull10_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull10_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull11.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull11_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull11_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull11_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull11_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull12.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull12_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull12_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull12_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull12_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull3.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull3_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull3_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull3_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull3_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull5.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull5_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull5_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull5_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull5_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull6.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull6_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull6_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull6_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull6_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull8.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull8_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull8_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull8_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull8_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull9.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull9_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull9_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_hull9_r.jpg
    runtime/textures/petipet/ensk outpost/pteno_light.jpg
    runtime/textures/petipet/ensk outpost/pteno_light_s.jpg
    runtime/textures/petipet/ensk outpost/pteno_stand.jpg
    runtime/textures/petipet/ensk outpost/pteno_stand_m.jpg
    runtime/textures/petipet/ensk outpost/pteno_stand_n.jpg
    runtime/textures/petipet/ensk outpost/pteno_stand_r.jpg
    I turned the important part blue to highlight it... This is after I redowned it.
    Do you know really you are in the wrong forum.   If you move your thread over to the Daz Studio forum you will maybe get some more people trying to help you.
    If you click on the Gear icon in your first post (the one next to the star), then click on edit from the drop down list.  On the edit screen go over to the left hand side and click on the arrow to get the drop down from the category box, and select Daz Studio Discussion.
  • LeanaLeana Posts: 13,653
    Looking at the product page I'd say that Ensk Outpost is a product not yet released, and that the scene you're trying to use is supposed to connect the station to outpost and so uses items from both products.
  • Richard HaseltineRichard Haseltine Posts: 112,009
    I think Jack broadly hinted that Outpost was yet to come, it may that the preset is a joint scene and won't work by design (though that should be made clear if so). You might do better to move this to the PC Members Only forum.
    I was suspecting that Richard H. But according to the help desk it should work......If I would have been informed of the latter I might have waited until all the peices were released......Thanks for all your help though
