Can't get dforce to work
So I finally tried dforce, downloaded and installed the open gl thing and it looks like it's working till the end when I get an error message to check the log. This is where the error begins. Anyone (@RichardHazeltine ?) know what went wrong?? Thanks
End of log where error is:
2018-03-14 16:33:57.930 Spring(7496, 7506) of node "Maid Dress" extended: rest length < collsion offset (0.0615887 < 0.20001)
2018-03-14 16:33:57.930 Spring(7497, 7505) of node "Maid Dress" extended: rest length < collsion offset (0.0728213 < 0.20001)
2018-03-14 16:33:57.930 Spring(7498, 7504) of node "Maid Dress" extended: rest length < collsion offset (0.0797386 < 0.20001)
2018-03-14 16:33:57.930 Spring(7499, 7503) of node "Maid Dress" extended: rest length < collsion offset (0.0854924 < 0.20001)
2018-03-14 16:33:57.946 Spring(7500, 7502) of node "Maid Dress" extended: rest length < collsion offset (0.0861119 < 0.20001)
2018-03-14 16:33:57.946 Shortest spring had length: 0.0165591
2018-03-14 16:33:58.259 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(30): Open CL notify: Invalid argument size.
2018-03-14 16:33:58.259 WARNING: ..\..\..\src\dzdynamicsengine.cpp(2493): ERROR: clSetKernelArg (-51)
2018-03-14 16:33:58.415 Total Simulation Time: 10.19 seconds
  • Open CL and Open GL are two different things. DForce requires either your GPU or CPU to support a specific version of Open CL (not Open GL).
    I downloaded the one that is on the Start Here section about dforce... opencl_runtime_16.1.3_x64_setup.msi
  • Ok, that's for your Intel CPU. What OpenCL device did you specify in Daz Studio, GPU or CPU?
    CPU, my laptop is CPU only.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,984
    @wonderland, when you ran and installed that runtime thingy did it ask you to uninstall something as well?  That's where I stopped the process because I was nervous about uninstalling something.  I am actually using a CPU only system at the moment so I am keeping an eye on your progress.  I have been left behind on the dforce train, still waiting for a cab to get to the station.
    Yes, I uninstalled the original Intel graphic driver. Everything runs fine with the new one, but I still can't get dforce to work... Where is @RichardHazeltine ???
    In the UK, where it is almost midnight.
  • BeeMKayBeeMKay Posts: 7,019
    @wonderland, have you tried to get something smaller to work, like a simple blanket in the test scene that comes with the dforce package? On first glance I'd say you are running into an out of memory error.
