Have problem to load up a set named "Classic Deco"
Download and install this nice scene!
The folders are in correct places and the files are in the folders and looks ok,
but something is not working!
It is install under DAZ Studio formats - My Library - Environments - Architecture - Classic Deco/ - Materials
- Scene
The Content Manager don't show anything! If I select go to folder on computer for the folders Materials and Scene I can see all files there!
I also tried to found under props if there is anything for Classic Deco but it is not!
Hm don't understand this!
Any idea about this?
Alf
I don't have this set, but it appears to come in CR2 (Poser) and also as a .DAZ Scene file as well. You seem to be looking under Materials.
How did you install this? If you used the DIM, then you can run it, and in the Installed tab, right click on the item, and you will be able to get a list of files that were installed, and where they were installed into.
Agreed Classic Deco should appear in your figures library. I have it in a folder called "Classic Deco", using the default path when installing to my Poser runtime.
Thanks for the reply!
I think it was my fault just getting little confused of all different files!
I am not using DIM cause I tried it once and it did not end up as I wanted!
I will not use DIM until I have uninstall everything and reinstall DAZ! OK
Some of the files I first download was for MAC OS! That make me confused
and then begin to download something else!
Now I download two more files that seem to be missing!
I just install it in the default settings!
Can someone remind me of the different with files
with extension of:
trx
ds
dpc
Thanks!
I begin to get little to old!
Alf
There is this list in the help centre https://helpdaz.zendesk.com/entries/22890557-Understanding-Content-File-Types
Thanks!
That really help!
Alf
