Alien Queen for G8F - any chance there's one coming for G8M?
this character looks so awesome! except, personally, for 1 thing.. it's female. i'd love it for G8M, this skin is breathtaking, and the head morph is excellent!
now i checked @Daveyabbo's page, they seem to only create female characters (up to now), so i'm not holding my breath..
but i'd be very happy to be proved wrong! so if you happen to read this, @Daveyabbo... ^^
theoretically, i could use @Agentunawares' transgender morph and make my G8F look male, but the only other body morphs for G8F i have (since i don't use females as such, why waste $) are DieTrying's V4 morphs ported to G8F, i.e. not so much mann-ish stuff, not so much choice on body, i was not so happy with the "males" i created up to now. not even mentioning the hassle if i want to use/apply the standard G8M male anatomical elements - on top of trying to texture them to match that is, obviously.
  • agent unawaresagent unawares Posts: 3,513
    You can also use Transfer Utility to send morphs from the female base to the male base, and then use UV Swap to switch the textures. This is my preferred method for getting a male character from a female one, as you get all the benefits of the male base like native morphs and a normally modeled chest. Problem is that Alien Queen looks like one of the characters that really needs its HD component, and those can't be transferred this way.
  • Dial the breasts down, the muscularity up, and stick whatever pokey-stick of choice on it, then render-away!
    LMAO!
  • manekiNekomanekiNeko Posts: 1,456
    yeah sure, he's alien right? shapes don't matter much, those guys are weird anyways XDDD
    i don't have UV swap yet.. and i'll have to familiarize myself better with transfer utility.. no risk to botch my standard G8 with this?
    ugh. the HD part of your info does not bode well >_<
    There is no risk that you will break your normal G8. The only way you can do that is if you save over an existing morph or save a morph transfer that is broken and it is not easy to do accidentally since you have to go all the way through File>Save As>Support Asset>Morph Assets... and then pick the morph. (You can also break things by doing that same thing, but pick Save Modified Assets, which I have never found a reason to actually do, ever.)
