FBX and Texture Atlas help
assmonkeyassmonkey Posts: 0
I have no idea where to even find them.
Well, I did find the Texture plug-in (pushed the F3 button) and did in fact move it to the Tools toolbar...and that didn't show up.
And I can't even find FBX
    edited June 2013
    FBX is a file type. You'll find it under File > Export and File > Import.
    Texture Atlas, if you're using the City Limits layout, will be on the right hand side and look like Earth.
    Post edited by Lissa_xyz on
  • assmonkeyassmonkey Posts: 0
    is FBX only useable for AutoDesk?
    That I'm not sure.
    Thanks for the help
    I'll look to see if UDK can work with FBX files
  • Richard HaseltineRichard Haseltine Posts: 110,284
    FBX is fairly widely supported, though there can be little wrinkles in the process.
    Still don't know the issue on way the Texture plug-in isn't even showing up
  • srieschsriesch Posts: 4,243
    I have the following notes, unverified, for how to set up DS after installation so I can see the Texture Atlas icon (the globe) in the taskbar. Hopefully this will be helpful:
    Window > Workspace > Customize: In the Actions (left side) scroll down to and expand Texture Atlas, then drag that icon to the Tool Bars tab on the right side, dropping it in the whatever menu you want to see it in (for example, I chose the Create menu just because it was handy.)
