How do I convert Poser models to Daz models?
I have some older ones that weren't released for both.
Post edited by buttercupsaiyajin_b3ffb4c8a4 on
Normally the models will still work in DS. Mats may need tweaking. If you bought them at the Daz shop you can install them directly into Daz Studio using DIM
products which use the Cloth room or Hair room in Poser will now work in DS. Products that are textured using only Poser shaders will give you problems.
You have to put them in the runtime folder within your set DAZ3D libary.
If you are unsure where that is press F2 go to Content and Content Directonery manager
Then in DAZ3D go to your Content Libary (Not Smart Content) and click on Poser Formats. There you should see your models.
