Adding pose controls
not sure if this is the right place but is there a way i can add pose controls such as twist or side to side to a body part that doesnt have them?
  • chris-2599934chris-2599934 Posts: 1,958
    Dunno about adding them, but you can make them show up when they're present but hidden.
    On the Parameters tab, click the options button (the four horizontal lines with a solid triangle pointing at them, above the tabs in the sidebar). Check "Show hidden properties." You'll then see a load of extra greyed-out properties on most bones.
  • sigh i wanted to add some controls to the tips of the toes for a scene
  • Richard HaseltineRichard Haseltine Posts: 110,536
    You may, I think, be wanting to add new bones. That is certainly possible (Joint Editor right-click menu with the parent bone selected) but then you have to give them influence on the mesh (weight-editing tools if this is a weight-mapped figure like a Genesis).
