How does one increase the size of the font used in the UI?
I'm set to factory defaults all around, but the fonts used in product library, etc. are almost too small to read.  Where does this get changed?
  • Richard HaseltineRichard Haseltine Posts: 111,851
    Daz studio can be adjusted only using the system font scaling setting in Windows at this time, proper UI scaling is being worked on but as it requires moving everything to a later version of the Qt framework and has obvious potential for geenrating issues it is taking time.
  • In case Daz developers are listening, I'd love to see that capability as well.
  • This has been an issue for a long time but Daz simply ignors it...I gave up hoping they would fix the problem long time ago but they have not and evidently, will not!
  • namffuaknamffuak Posts: 4,527
    Not being ignored and actively being worked on - but totally non-trivial, as it requires replacing the entire UI framework
  • Thanks, namffuak, looking forward to whenever they can accomodate.
  • dracorndracorn Posts: 2,384
    Me too.  I'm tired of squinting at the teeny letters.
    For me what is worse than the size is the dark gray color which is so close to the background I can barely read it.  I run into this a lot in the Parameters tab, especially when looking at morphs for V4/M4 and other older models.  You know, Actor, Morphs, Imported, and this huge unsorted list comes up, all dark gray.
    I know I can change the color of the fonts, but I'm not sure which one.
    I have no doubt that it is a non-trivial issue to work on and not have go KABOOM like dForce clothing. But have you heard of any time line for a change?
