Daz 4.6 Keeps crashing when I fit clothing onto V4
2getit2getit Posts: 0
The bug that im getting says this
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtCore4.dll" at 0033:000000006801C3B8, QEventLoop::exit()+8 byte(s)
  • StratDragonStratDragon Posts: 3,290
    Have you rebooted since you got that or are you just relaunching studio? Reboot the system, then try again.
    What are your system specs are what clothing are you getting the error in? Are you getting with with any clothing or one specific thing?
  • 2getit2getit Posts: 0
    It hasn't crashed on me in the past 20 mins, but my I have a 6 core with 16 gigs of ram on 64 bit in win 7
    I have rebooted.. The clothing I'm using is from the renderosity store, nothing with high textures or polygons
    the error you showed probably had nothing to do with amount of RAM you had, it might be a corruption of RAM or RAM in your CPU cache that isn't getting flushed until you reboot, Not all clothing is equal, I have found a handful of items that can crash when you apply them, but the vast majority don't in which case if its a specific item someone else may have it, find the crash and report it back to the vendor or to Daz3D in the hopes that someone can identify the cause.
  • LindseyLindsey Posts: 2,017
    edited June 2013
    Are you an Octane Render DAZ Plugin user? There was a known bug in the Octane Render DAZ Plugin 1.0.111.2019 that will throw that QtCore4.dll error message when using AutoFit. It was fixed in version 1.0.111.2118.
    Post edited by Lindsey on
