Strange Lag in Daz 4.6
This is the strangest thing. I just out daz3d 4.6 on my desktop, and now, I have the strangest lag issues ever. HDD test good, CPU and GPU, good, RAM good. I had a professional look at everything to find out WTH was going on. Crysis 3, almost max setting, NP. Daz3d 4.6.... Can't even load Genesis with out taking forever. once loaded it takes forever to respond. I load anything else it fails to respond and crashes.
Hardware as per DXDIAG.
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 11/19/09 19:58:42 Ver: 08.00.15
Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
Memory: 12288MB RAM
Available OS Memory: 12286MB RAM
Card name: ATI Radeon HD 5700 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x68B8)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV;_68B8&SUBSYS;_29901682&REV;_00
Display Memory: 6895 MB
Dedicated Memory: 1008 MB
Shared Memory: 5887 MB
One quick question - are you using the 32 bit or 64 bit version of Daz?
Either should work but the 64bit can use more of your RAM. Still using the 32 bit shouldn't be causing a crash or lag but it might help someone have an idea of what your problem might be if they know what version you have.
im having the same issue today im using 32 bit. im having rendering issues whats going on daz lol I try to render animations and I get ctd
I am using the 64 bit. even more strange. Ram used, only 900 mb. CPU is next to nil.
