How to change Default Render Settings
KlaudMKlaudM Posts: 76
Hi guys, is there a way to change the default settings permanently? Need to edit some file? (I'm pretty sure about this but dunno which is the file)
I'd like to have my settings loaded everytime I press "default" without need to manually load the preset or a new scene because I do this operation many many times also in the same scene.
Thanks.
Post edited by KlaudM on
  • FishtalesFishtales Posts: 6,228
    Set up a blank scene with your default settings, save it as _default-scene and have it load at startup or New.
    To do this go to Preferences/Startup/Load File and browse to where the _default-scene is and choose it.
    Next go to Preferences/Scene/Load File and choose the same file.
    Click on Accept.
    Close and reopen Studio and that should now work.
  • KlaudMKlaudM Posts: 76
    edited March 2018
    Click on Accept.
    Thanks but this doesn't help, as I wrote I'd like to have my setting loaded when I press default not when I launch Daz or create a new scene.
    I think is very simple if someone know where the default render settings is located, for sure just need to copy/paste custom settings or change a path
    I do that by saving the settings as a Render Preset then add that to the Script Menu. Whenever I want my default settings I then go to Script Menu and scroll down to My Default Render Settings and when I release the mouse button they are then set in whatever render I am doing.
