Lights and instancing
Does it affect recourses or render times to instance lights or not? I created instances of a road section but the spotlights for the street lamps didn't instance with it so each instance has it's own spotlights parented to it and I was wondering if it would make a difference to go through and just instance 1 spotlight instead of having a ton of individual spotlights.
  • Richard HaseltineRichard Haseltine Posts: 112,059
    There's no benefit in instancing lights, so no it isn't supported.
  • kaotkblisskaotkbliss Posts: 2,918
    Except for the benefit of being able to change the original and having it affect the instances. I just wasn't sure if it used less resources or not.
    Thank you for answering :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,843
    well I think there definately is with emission shaders on props
    Yes, for the geometry.
    Fortunately with emission shaders on props, those get instanced when the prop is instanced :) so that makes that easy
