Genesis 8 custom Morphs Creation Problem
TamunaTamuna Posts: 82
In short: can't do it. The Morph Loader Pro gives me a notice: "Warning: Geometry did not match, failed to create morph."
I've doublechecked my process and import/export parameters in several different tutorials. Can't get rid of the error. Then I tested the method on Genesis 3 - and it worked, I took the exact same steps and imported and exported with the exact same parameters in both Daz Studio and my modeling program. I didn't change the geometry when creating my morphs for Gen 8, I assure you of that and I ran several tests, comparing Gen 8 morph dials to Gen 3 dials - I've noticed Gen 3 didn't have some eyelash morphs that Gen 8 has (I've tried them exported at 100% as was the default setting and then 100% - no difference, also mouth realism and navel settings - tried to do it like in G3 AND as it's set by default in G8. Again, no difference).. Another thing I tried was using the base model exported from Daz just as it was, but MLP gave me the same warning. It's the same story with both Female and Male 8.
Has anyone had the same problem? Have there been any new features/parameters added in Genesis 8 that I need to account for when exporting, or are these bugs I need to ask support for?
EDIT: Just wanted to point out that I'm exporting to Maya, I've just found someone else had the similar problem but they were taken care of in GoZ settings. Can't find anything for the regular exporter though :(
Post edited by Tamuna on
  • Oso3DOso3D Posts: 15,115
    Did you make sure to remove the eyelashes before exporting?
  • TamunaTamuna Posts: 82
    Grrrr! I knew it would be some pesky new detail like this! angry
    Anyway, thank you so much! It works now. yes
