Noob here. Why does my character appear super bright once rendered?
Studio 4.10 (64-bit). Using Victoria 7 only with no lights whatsoever, just a blank canvas and the figure. When I rendershe becomes blinding by a white light.
544 x 436 - 43K
  • Do you have it set to Dome only or Dome and Scene in the render settings? Render > Render Settings at the menu bar?
    You might have a very bright HDRI set up. Set it to Scene only or lower the Environment Intensity or Environment Map.
    Other than that you might have messed up your ISO Film, F/Stop and so on in Tone Mapping.
    maybe it helps if you click at default at the render settings
  • FishtalesFishtales Posts: 6,232
    It looks like you have left the camera headlamp on.
  • BeeMKayBeeMKay Posts: 7,019
    Yes, check your camera. Select it in the scene tab, go to the parameter tab and look for "headlamp". If it is set to aotomatic, set it to "off".
  • DSRTDSRT Posts: 1
    Thank you, thank you, thank you lol I could not figure this out until I read this comment
