Is it possible to resize the Reference Grid.
Blackbirdx61
Been trying to make some simple Morphs and UVs with Hex; (as Sculpris does not work in Win 10).
But I find even though I am saving the OBJ using Hex/DaZ Standards, 1:1cm.
The OBJ when brought in is Huge compared to the Reference Grid. Is it possible to Expand the Ref Grid? Without adversely affecting the OBJ on import.
Thanks BB.
Yes you can change the size of the grid - Edit, Preference Editor, User Interface, Grid. Then change the Grid Size.
Personally I use DAZ Studio and Hexagon defaults, see screen grab (click for bigger view, I can never remember how to display the image full size).
Are you exporting an OBJ or using the DS-Hexagon Bridge ?
Hexaogon at the moment is not very good with UV maps, I'd suggest unfolding your prop, export it as an OBJ and use UV mapper classic or UV Viewer (both free) to create your map, that way you can choose the size map you want.
Thanks Much John, I've been exporting OBJ; will check out the UV Mapper/Viewer apps you mentioned.
: ) BB.
Sculptris doesn't work in Windows 10? That's the first I've heard that.
