HDRI with LuxRender plugin
Hello
Since yesterday I use LuxRender.
Can one tell me how to adjust LuxRender, so that I can render with HDRI files ? So, about HDRI lighting
Where do I need to load the HDRI file. Normal in Carrara, or anywhere else that I need to include?
Sorry for my English.
I'am from Germany
regards
Mark
  • 3DAGE3DAGE Posts: 3,321
    edited June 2013
    HI Mark
    for Luxus ;
    Add a "Lux Infinite" light, then you'll see a box, for the Map,. browse to your HDRI
    Set the renderer to Luxus,. and render.
    (see pic2)
    Normally, in Carrara,. using the "photorealistic" renderer,.
    Select the "Scene" in the instance list, (bottom right) then select the "Background", in the (top right) section.
    then add your HDRI,.
    to enable HDRI, you need to set the rendering option to (skylight)
    (See pic1)
    hope it helps :)
    510 x 759 - 101K
    1025 x 794 - 152K
    Post edited by 3DAGE on
  • edited December 1969
    Thanks!
    Great Tipp
