Some shortcuts gone?
Ravioli777Ravioli777 Posts: 9
I used to use ctrl-z quite a bit to undo and also ctrl-d to drop an object to the floor. Today the shortcuts don't work, and aren't listed in the drop down menus. This happen to anyone else?
  • SiscaSisca Posts: 875
    Just checked and both work for me along with showing them as shortcuts on the menu.
  • Ravioli777Ravioli777 Posts: 9
    I'm using ds 4.5 if that makes a difference...
  • Richard HaseltineRichard Haseltine Posts: 111,958
    Window>Workspace>Select Layout and choose the layout you are using to reset the custom actions, or go to the AppData folder (Windows) for DS - C:\Users\You\AppData\Roaming\DAZ 3D\Studio 4 on Windows Vista or later, you will need to enable the display of hidden files and folders in Control Panel>Folder Options - and delete actions.dsx to force DS to recreate the default actions and shortcuts.
    Resetting the layout did the trick. Thanks!
