daz3d 4.5 rc 2 problems
hi im try to understand why from when i installed the new 4.5.049 rc 2 i cant load some objects correct
if i try to load " mr hyde pants" they load but not object is in the scene
same is happening with " way of samurai" i cant load part of the objects i see the name on scene but nothing there
please help
  • adamr001adamr001 Posts: 1,322
    Are you seeing a "Duplicate ID found" error message? If so, you need to reset the downloads for the affected content and reinstall it as it has been updated to correct this issue.
  • edited December 1969
    no i just see the name but not abject i did rinstall mr heyde and way of samurai many times but it still the same no object in scen appear but i can open the obj in zbrush
  • DoctorJellybeanDoctorJellybean Posts: 10,191
    Check the installer files; they should be:
    13894_MrHydeforGenesis_1.3_trx.exe
    14039_WayOfTheSamurai_1.2_trx.exe
    If they are not the same, reset your downloads to get the updated files. Both work for me in 4.5
    i have to check im at work now but how do i reset my downloads is first time its happening to me. there is a command to do that
    and after i reset it do i have to reinstall all my contents ?
    Log in into your account (DAZ store), then go to Itemized Order History. Find the two items and click on Reset on the right. To be safe, uninstall the 2 products you have problems with (Hyde and Samurai) and then install the new files. If you don't have uninstallers for those 2, I think the installers will recommend to uninstall it for you.
