Cheirocrates les romantiques Texture missing
MartialMartial Posts: 431
Bonjour
I just inatall this new product and poser ask me about
I do an intensive search with Ultrafilesearch exe on all my drives and find nowhere this jpg
Is it missing?
Suggestio please ?
Thanks
  • HeraHera Posts: 1,972
    edited June 2013
    Hello!
    I cannot use this product at all, all I get is error messages. I have Cheirocrates selected when I try to apply the Less Romantiques mat pose and all I get is these error messages:
    Some assets needed to load the files were missing. The content may not work as expected. The following files could not be found.
    /data/Jack Tomalin/Cheir/CHE_Light/che_light_3972.dsf
    /data/Jack Tomalin/Cheir/CHE_Gr_Sd_Walk_1/che_gr_sd_walk_1_532.dsf
    /data/Jack Tomalin/Cheir/CHE_Planter/che_planter_1740.dsf
    /data/Jack Tomalin/Cheir/CHE_Fence/che_fence_6380.dsf
    /data/Jack Tomalin/Cheir/CHE_Gr_Rd/che_gr_rd_9.dsf
    /data/Jack Tomalin/Cheir/CHE_Tower/che_tower_67960.dsf
    /data/Jack Tomalin/Cheir/CHE_Bench/che_bench_3740.dsf
    Then it loads an empty block into my picture and the materials does not become applied to the Cheirocrates set.
    Post edited by Hera on
  • Richard HaseltineRichard Haseltine Posts: 111,965
    Herakleia said:
    Hello!
    I cannot use this product at all, all I guett is error messages. I have Cheirocrates selected when I try to apply the Less Romantiques mat pose and all I get is these error messages:
    Sounds as if you are opening a scene file, not the materials preset.
  • Satira CapriccioSatira Capriccio Posts: 523
    edited June 2013
    Using Windows Explorer, I copied fence_pst.jpg and renamed the copy fence_pstAddon.jpg. fence_pst.jpg doesn't actually seem to be used in either of the two Poser preload cr2s.
    While there may very well be differences between the base textures and the Addon textures, I couldn't see any.
    Also, one of the lights (che_light_3) in preload !LR_Pre_Sec_1 does not load with the correct settings.
    And ... another also. I just tried loading the Bridge of Cheirocrates BRCH_Bank and the three water textures (brch_st_water.jpg, brch_st_water_B.jpg, brch_st_water_T.jpg) are missing from the Bridge_of_Cher folder.
    Martial said:
    Bonjour
    Is it missing?
    Suggestio please ?
    Thanks
    Post edited by Satira Capriccio on
  • MartialMartial Posts: 431
    edited June 2013
    Thanks for the suggestion
    For now i just change the name for fence_pst.jpg for fence_pstAddon.jpg and load the file
    But i hope the vendor see this post and add the missing file to his product
    Post edited by Martial on
