Man-Wolf - Face Texture Out of Place? Please Help Fix
As you can see, his body texture looks fine, but his face texture... Well, something's out of whack, because his nose is not sitting on his actual nose.  (The other face textures have the same problem.)
I'm using Poser Pro 2014 with DSON to import this guy -- and other than the face, he looks great.
Can someone help me fix this, please?
Thanks!
-- Steve S.
    Can't see any attachments, but are you sure you have the right uv map for the face?
  • Can't see any attachments, but are you sure you have the right uv map for the face?
    You can't see the pic?
    Hmm...
    Not sure why that would be.  It's big and clear on my screen.
    I _think_ I've got the right texture map for the face -- I was using the supplied maps with the click-to-change options, not anything of my own.
    -- SDSullivan
  • SixDsSixDs Posts: 2,384
    I can't see it either, Stephen. If I right click on the space where it should be the popup seems to know that it is supposed to be an image, but the properties for it indicate a long alphanumeric string:
    ReNW1iuHPugQrmT6Ef3VCReQ9V7KEA7Qz_-Sg53PCL7YvXag29wRyTKCVE2uoL7wK8_QzmtYeUw_QDoqKf9QlDd_GAhkTr-gq0yj0XG9LK7LFwPIaLhHwJyjRYIosZa5l1i9q-HW8Onv4I8waSNBMYjjK-MqWBH62G0_h7Sm5EfeOHb0UAX5dp_SU3Gb7782XETJuRqodNSeTOOlrRFiNftEcO7w6nXG2eLjyX84pi0pq-lDBNTRu5SXW3f2wgpMwxMpVsA5e6oSyhsVl2lanW4HeO1bzCyWvMfrKqnO3jpCe5skCqQEn4tk8YEsPjIQInmHzCwY8kb-zJDMRp1qKyGdm0xXLXATMvHROVcgkXscQoHFEvqQIoFk1utFsDJAWeorEHxzTnGLDwTQN6Jj1buhRtMB7zdrQbZdqXgoDT2iZs2cD9rq9oBz6zCyruw7zk0WYvirsbhtbGgo74cmwFBj_Pao65C4EyefFE5d-X56mjqz0hLvg1lCKYnPvzAl7LhwNlUqT_tYR_pd185N0G-LzYAA23ySLASeYWftVXFJePf2-ICpHioRAdG0LLE7ZdTKIdjWvkFV6Z31cUQokZq-ssIf2rkqFEjw7Rw=w765-h641-no
    I have absolutely no idea what that is, but if there were an image the properties would show its filename and extension (.jpg or whatever).
  • I can't see it either, Stephen. If I right click on the space where it should be the popup seems to know that it is supposed to be an image, but the properties for it indicate a long alphanumeric string:
    Hmm... It was supposed to be an attached image.
    But does this forum not allow attached images?  Do I have to point it offsite somewhere?
    If so, that could explain why y'all can't see it and it shows up fine on my screen -- which it still does.  (I'm circling back to this problem, after working on other things.)
    Can I NOT attach images here?
    Or maybe I need to attach it as a file -- not use the image post in the top bar?
    I'll try to attach it this time.
    -- Steve
    765 x 641 - 50K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,505
    you cannot delete the attachments thumb of your attached image after linking it
    I see your thumb in your last post fine
    yes you need the manwolf UV by looks, you need to load the character into Poser not just apply the textures
    if you have no cr2 D3D DSON loader works well
    http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
  • Hmm... I thought I _did_ load the character into Poser.
    And then I applied the skin using the supplied MAT pose, I think.
    And I think it used DSON to get it.
    What did I do wrong?
    (And how is the DSON app  you linked to different from the DAZ one?)
    Thanks!
  • I reinstalled the files into my DAZ (for Poser) runtime, reloaded it again, and got the same result.
    I also loaded up the Sasquatch figure the same way.
    And got a similar result with the sasquatch/yeti UV.
    Though the body loads up normally on both these RawArt characters -- and though the Freak 5 base for Sasquatch looked fine...
    The UVs don't seem to line up right on the geometries.
    You can see the mismatch on the face, and even more on those triangle-like patches on the thighs.
    I'm loading the UV from the Mat files.  I even tried to load them from the Poser file -- with no difference.
    Why?
    -- Steve
    765 x 641 - 38K
    765 x 641 - 91K
