Resetting a figures coordinates
Hi,
Sometimes, the coordinates of figures seem to be messed up. Often it happens when the figure is sitting or some pose does it. Then usinf tranlsate or rotate becomes very difficult.
Example... A simple purely X rotation becomes partly an x rotation, partly a y rotation and partly a z rotation. Is there any way to reset the figure's coordinates to make the rotation simple again?
If you go to the tools parameter and select the universal tool there is an option to choose local coordinates or world coordinates for rotations. To reset the figure pose to 0,0,0 select the figure root bone in the scene tab, go to parameters pane and right click to bring up a menu, select zero selected item's pose. If the hip bone is offset which often happen when applying premade poses, select the hip bone and use the same method.
