need help with daz 4.5 upgrade
wolfman7367
Ever since I upgraded to daz 4.5 my genesis has disappeared. All I see is blocks instead of the figure
Some assests needed to load the file were missing The content may not work as expected
The following files cannot be found
/data/DAZ 3D/Genesis/Base/Genesis.dsf
any way to fix this?
Genesis is no longer included in the program installer, it is in a separate installer named Genesis Starter Essentials. I only see the latest version of GSE in my Product Library so you may need to upgrade to the latest version of Studio to avoid any conflicts.
In addition, the program won't find Genesis.dsf because it doesn't exist any more — the Genesis figure (and all new stuff released recently) now uses .duf files, so after you have the Essentials installed you need to look for the Genesis.duf file. It should be in the same place as the old file.
