Specular light setting switching to specular only randomly
As title says. I will set up my keyframes, pose everything needed and then  I have to go through all the frames one at a time to make certain the lights did not randomly switch to 'specular only' all by themselves. Then best part is when I check the frames one at a time and then a previously checked frame decides to switch without any permission from me and it is not discovered until 6 hours later when the render is finished.This is a gmae breaker. It seems like spot light and linear point of lights are the big problems.
  • Richard HaseltineRichard Haseltine Posts: 111,294
    Are the lights animating or static? If they are static you could try selecting them and uisng Edit>Object>Clear Aniamtion>Clear Selected item(s) with the lights selected.
  • They are animated.Even after clearing them and resetting the keyframes the same issue occurs....random changes to the mode from 'on' to 'specular only'. Moving a light or changing the lights intensity should not cause a light to switch to specular only. Annoying bug that wastes way too much of my time....especially when I have to click through 400 frames 1 at a time and hope that I get lucky enough for the lights not to randomly spitch modes on me.
    edited March 2018
    Try this script - I think it will remove animation from the Ilumination property only, leaving just the starting value. Paste it into the ScriptIDE pane (Window>Panes(Tabs)>ScriptIDE), click the Execute button to run it with a couple of test scene, and if it seems to be working use the File>Save Script As command in the ScriptIDE menus (not the main menu bar) to save it. You can then find it in a content pane, right-click, and select Create Custom Action to put it in the Scripts menu for easy access.
    // Remove Illumination animation from selected nodes// copyright (c) Richard Haseltine, March 2018// Get the selected itemsvar nodes = Scene.getSelectedNodeList();var typeControl;// Go through nodesfor (var n = 0 ; n < nodes.length ; n++ ) {	// check for an illumination property	typeControl = nodes[ n ].findPropertyByLabel( "Illumination" );	// if there wasn't one go to the next node	if ( ! typeControl ) {		continue;	}	// does the property have multiple keys? if not go to the next node	if ( typeControl.getNumKeys() < 2 ) {		continue;	}	// delete the keys, leaving only one value	typeControl.deleteKeys( 1 , typeControl.getNumKeys() - 1);}
    Also, please open a Technical Support ticket to report this as a possible bug
  • I had exactly the same problem. Thanks Richard the script worked a treat
  • Richard Haseltine: you are a godsend. HAD the same problem in DS v4.10 & already went through process of manually entering keyframes that would switch the lights back to on, one-by-one, manually! Your script worked marvelously. Tears, man, tears!!
