Clothes fitting bug?
Hello,
this happens to me way too often.
i fit clothes on any Genesis model, and they look alright, so i save the scene for later use, after i close Daz3d and re-open it, i load the file, the clothes don't fit well at all.
i check the settings and everything is left the same, a temp solution was to bump up the collision and smoothing but that squishes lots of details.
please help!
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 112,099
    You could also try fitting the clothes to None, then back to the figure.
    Is you figure using any custom morphs that have not yet been saved as Morph Assets?
  • GreenBeanGreenBean Posts: 49
    actually yes!
    i do tons of custom morphs using Zbrush, but see, they work really well after i import them back into daz.
    but if i save the scene, close it and the re-open it the clothes look really off!
    and yes, i don't have these morphs saved, since i want them to be used for one figure exclusively and if i save em it would cluster the shaping tab.
    do you think that it might be the problem?
    Thank you for your reply! i really appreciate it!
    Yes, I think this is probably an issue with embedded vs asset morphs - please open a Technical Support ticket to report it as a possible bug https://www.daz3d.com/help/help-contact-us
    all done! ticket submitted!
    Thank you.
