can't save
I was making changes to a scene I haven't worked on in a while and I can't save.
I screen shot this to explain myself.
Respond ASAP.
1383 x 785 - 161K
  • Richard HaseltineRichard Haseltine Posts: 111,306
    To where were you trying to sae?
  • Amazon12Amazon12 Posts: 67
    the hard drive on my computer
    Yes, but which folder? Some foldrs are given a special status by the operating system. Also, if you created the folder in soemthing running with adminsitrator privileges it will be locked to ordinary use (which is why the Run as Administrator command should not be used unless specifically required).
    Come to think of it, I DID open Daz as an Administrator.
    edited March 2018
    That may be the issue then, you can check the permissions on the folder by right-clicking on it in Explorer, selecting properties, and then looking at the Security tab.
