Converting quads to triangles
I'm starting to work on a plug-in project that will add AMD's open source version of ProRender as a render engine and was wondering what the most efficient way to convert quads was since the current implementation I'm working with only has native support for triangles. Any suggestions?
  • TotteTotte Posts: 15,229
    Hi!
    I found this trick which I used in script test, which probably can work on DzFacets too (I haven't tested).
    The idea is, read the Facets, if they are quads
    turn them into tris using
    tri 1: oFacet.vertId1, oFacet.vertId2, oFacet.vertId3
    tri 2: oFacet.vertId1, oFacet.vertId3, oFacet.vertId4
     I tried it processing an exported OBJ but will "soon" try it directly on a DzFacet.
