DAZ Crashes with IRAY and GPUs - Crashes PC
pfunkyfize
Hi all, I am trying to diagnose my crashing problems in Studio when I use IRAY with my 2 Nvidia Geforce 980 TIs. The crash kills DAZ and either freezes my PC or gives me the BSOD in Windows 10.
OS/Hardware:
Windows 10. DAZ Studio 4.10.0.123. One internal 980 TI and one external 980 TI.
Attempted solutions:
Updated all drivers for CPU (including OpenCL) and GPU drivers. Uninstalled Studio and reinstalled it. Tested a render using GPUs separately.
Circumstances:
For a year I have been pretty happy with my 2x 980s and they have been working pretty well and giving me a huge speed gain for IRAY rendering. About a week ago renders all of a sudden just stopped completing and the PC either crashes or BSODs. Now I can only get a successful IRAY render completed when I use CPU rendering only as the photoreal device. I have even tried using both GPUs separately but would get the same results - PC hangs or BSOD after about a minute or two of rendering on to a file or rendering in the viewport. The error messages on the BSODs are different every time and sometimes there are no messages. I grabbed a section of my log where the error occurs and when I restart Studio. The log starts where I load a file called 'Archeology-Dig-02.duf' where it starts to render then crashes. The log picks up again when I start DAZ back up and ends where I manually disable all the GPUs.
As far as I know, I have not done anything drastic to my render settings and have been at the most recent Studio version since the update came out months ago without any problems. I am trying to rule out if it is a hardware problem. The external GPU has its own power supply so it's not competing for voltage and the internal GPU has been inside the PC long before I had the second external GPU and it did well without voltage problems. My 3d video games seem to be working fine too. There have been no electrical mishaps as far as I know of in the timeframe of the sudden crashing like storms causing sudden powerouttages and power spikes. I have had many power outtages where I live and the power surges have never affected my PC. So I am thinking this is a DAZ Studio issue but could use some help locating the problems.
Thanks, log attached-
The log has a warning:
WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MDLC:COMPILER): 1.0 MDLC comp warn : C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\daz_3d\irayubermaterial.mdl(422,20): conversion from 'float' to 'color' must be explicit
I've never noticed that one before... Usually in pprogramming code, unhandled conversions of anything usually causes something to blow up.
But anyway, I am grasping at straws at this point so any suggestions and/or common experiences would be appreciated. Thanks!
I get the same problem. Most often a BSOD. Also on Windows 10, rendering with Nvidia Titan X, using either IRAY or the integrated Octane plugin. All my drivers are updated and tried reinstalling.
I am looking around other technical forums for the answer to this, my rig was working with 2 separate GPUs before. Good to know i'm not the only one...
Here's the kind of stuff I typically do to diagnose issues like this:
When you have a difficult problem, it’s important that you first simplify your computer so it’s easier to isolate the source of the problem(s). Get rid of all unnecessary components and see if you can get your computer working, then add them back one at a time and check them individually until the problem re-appears.
I had similar issue, following resolved the problem for me. I used MSI Afterburner to lower the clock temprorly before starting Daz3D. May be you can try:
https://forums.tomshardware.com/threads/display-driver-nvlddmkm-stopped-responding-and-has-successfully-recovered.3471967/
Factory overclocked model (as suspected). GPU clocks are
boost 1137 MHz / base 1059 MHz
Nvidia reference clocks are
boost 1085 MHz / base 1020 MHz
Reduce clocks to Nvidia reference levels.
PSU is fine BTW. Nvidia recommends minimum 300W, MSI recommends 400W (for this card model).
