Image saved as "r"
Hey,
does somebody know why this script saves the image in my temp dir with the name "r" instead of "mytest.png"? cool
    (function(){    	var renderManager = App.getRenderMgr();         	var renderOptions = renderManager.getRenderOptions();		renderOptions.RenderImgTarget = renderOptions.DirectToFile;		renderOptions.renderImgFilename = "mytest.png";		renderOptions.applyChanges();		renderManager.doRender()    })();
  • SimonJMSimonJM Posts: 6,100
    I seem to recall that the temporary file saved by DS is called r.png, so until you actually do a 'save as' your save name wil lnot be applied.
  • jag11jag11 Posts: 885
    edited March 2018
    This line:
    ​should be:
    renderOptions.renderImgToId = renderOptions.DirectToFile;
    because the doc states:
    RenderImgTarget renderImgToId
    RenderImgTarget is an number with three possible values.
    Post edited by jag11 on
  • Hurdy3DHurdy3D Posts: 1,109
    edited March 2018
    Hey nice, this did the trick....
    so everything which is under Enumerations is a number.
    renderOptions.RenderImgTarget  = 3;
    worked and
    worked, too.
    Thank you for your help.
    But the scripts complains now about:
    Executing Script...QMetaObject::invokeMethod: No such method DzImageRenderHandler::getViewRenderHandler()Result: Script executed in 61 secs 321 msecs.
    Can I ignore this error?
    Post edited by Hurdy3D on
    No error or warning should be ignored, something might be missing, maybe if you post a streamlined version of the code could give us an idea.
    edited March 2018
    The complete code is
        (function(){    	var renderManager = App.getRenderMgr();         	var renderOptions = renderManager.getRenderOptions();		renderOptions.renderImgToId = renderOptions.DirectToFile;		renderOptions.renderImgFilename = "D:/render.png";		renderOptions.applyChanges();		renderManager.doRender()    })();
    It is not very complex, this are my first steps in daz scripting wink
